Farmall 400 steering u- joint
Mayor
After trying several options and cross references, I finally found the right u- joint for my 400 steering shaft.
That's the one I used on my H, local driveline place bent me over for $18, got another one from Inland Truck $6.
Yep ya can get cheaper U/Joints and for the steering it will be fine , BUT when it comes to drive lines i will pay for the Spicer and do it once. I will not buy u/joints from NAPA or the big box parts store ever again. Learned my lesion yeas back with my 88 Ford and NAPA joints i was lucky to get 6-7000 miles out of a joint , Truck was serviced every 3-3500 miles with oil changes and grease job ft. to rear and every time i went under that truck i had a joint out , not due to lack of grease but the needles were imbeded in the cross . Switched to Spicers and never had another problem in the next 200000 miles .
