The Farmall Super A is all a part. Looking at the brake lining I see where one side is fairly thick and the other side having a fair amount of wear to the point that the rivers are getting close to the surface.
So when I go into the brake shop to get them reclined what material do I request and how thick should it be?
I assume there are standard material thickness that can be used. Just want to make sure that I get maximum thickness so I do not need to revisit this.
