farmall43m
New User
I'm trying to get the 6 volt charging system to work on my Farmall M. I believe it has its original generator which is a Delco Remy model 1101355. There was no cutoff relay or regulator on the tractor when I bought it. I bought the 6v pos ground voltage regulator GDR6003 and hooked field-field, arm-gen, batt-ammeter, and L to coil. I flashed the Gen and Batt voltage regulator terminals to polarize. I was not able to get any indication of generator output on the ammeter after starting. Does anyone know if the GDR6003 regulator will work with this generator? Any other suggestions?
The tractor does have the 4 position lighting switch with the original field circuit resistor in place but there is no indication it was ever used. The resistor is shorted out.
Thanks!
Thanks!
