William1984
New User
Hello,
Currently in the process of restoring a 48 SA and hit a small stumbling block. Unable to turn the rear wheels. It did this while completely separated from the engine and front end. Shifter is in neutral, we reassembled the engine but can only turn crank by hand if clutch pedal is down. Can move shifter while pushing in clutch but the movement is erratic and doesn't line up with shifter grid. No movement at all from rear wheels. I've done a bit of homework and am wondering if it could be stuck in 2 gears or if the input shaft is jammed. In either case, or if its something else entirely, i'm not sure how to proceed. Would appreciate any advice anyone can offer.
Thanks in advance.
Thanks in advance.
