While changing the oil and filter for the first time, the canister was leaking at the bottom of the bolt. Looking at the parts catalogue, there is an o ring above the collar and bolt which I will replace. I also noticed a guide, seal circlip washer and spring which are not included on my assembly. Are these parts necessary inside the canister? Do they apply pressure to the new filter for a better seal? Also will any o ring work to stop the leak below the canister or is it specific to the 434 Farmall?
Thanks for your comments in advance. Robert
