Hello All,
First time tractor owner here and I have a question. My tractor is having issues. When i first start it and its cold i put it in first gear low and it goes fine for a while. But if i try to go any higher in gear or into the high gear the tractor does not move i let off the clutch and dont feel it want to move at all. But if I go back into first it will go when i let out the clutch, If i attempt to go up an incline it will not go. Not sure if its a clutch or fluid, etc.. My neighbor said to empty the hyd fluid make sure it has enough in it and refill because it sat for a year. that did not fix it. any ideas??
IH rookie
IH rookie
