Super M main bearings.
Hello all, so my engine guy took .030 off the main journals of the crank because it was so bad, and.020 off the rod journals. I can get rod bearings, but I'm not seeing any listings for.030 under mains. Anyone know where to get these, or am i out of luck? As always, you folks are the best, and have never failed me!! ...... Darryl
Search the internet for 356988R11 center main set and 356987R11 end bearings. Should find several different prices and some come up as complete main set and some each bearing set separate. Didn't have any trouble finding places to get them in a search.
my experience with crank turning the machinist locates the brg's before turning. and also turn to whats available. if you cant locate brg's no sense turning crank. piles of used cranks out there.
You could have that crank built up to use standard bearings.
You might want to use a different machine shop, though.
Mr. Slater! Can't thank you enough! Plugged in those part numbers in a google search and they came right up. All States A g Parts. Also Walmart? And they get them from Al State too! When i searched Farmall M main bearings i got nothing! But with your help, things are looking up. Thanks again. Like I always say, the people on here ARE the BEST!
