Farmall & IHC Tractors Discussion Forum |
1086 front engine seal leak
Author |
[Modern View] |
gbs
01-12-2019 18:19:58
After 3 times of replacing the front crankshaft pulley seal and having it still leak I don't know what I'm missing or where to go from here. Someone tell me what is the problem, I didn't see anything wrong with the first seal or wear band other than a small leak, the next one was installed with the new pump using the same wear band because it was is slick as glass, it leaked also, #3 this time the seal came with a new wear band which I didn't change because the old one was as good as the new one, checked the seal fit to the pulley it was good also there weren't any burrs or nicks on the pulley, installed the new seal same as before lubed it good and the pulley wear band as well, installed the pulley same as before now it leaks worse than before, when I could just see any oil I shut it down remove the pulley dust shield ran my finger along the outer edge of the seal where it mates up to the pump it was dry all the way around except at the very bottom, the best I could tell the oil is coming out between the seal lip and the pulley shaft ???????? what am I missing?
gbs
01-14-2019 18:04:48
Re: 1086 front engine seal leak in reply to gbs, 01-12-2019 18:19:58
Thanks for the replies, I might be wrong but if delayed action memory serves me right and by the help of the LORD I may have found the source of the problem, not going to start crowing yet, but will reply back in a couple days when I get a chance to pull it back off.
The tractor vet
01-14-2019 08:43:20
I was going to chime in but listen to Pete as he is like me and old timer I H wrench . Ya need to have the correct tools for the job and like Pete said how bad are your main bearings if that crank is floppen around you will never get a seal to hold.
gbs
01-13-2019 11:13:47
The first one was an IH brand the next 2 were national, it's not leaking from the key way there is no oil between the heavy washer held on with 3 bolts and the end of the crank, I can't see any oil leaking anywhere except where the seal lip runs on the wear sleeve , seals have been installed in the correct direction flush to the oil pump and a the reason I did not change the wear sleeve was the old one was as good as the new one there isn't a groove or scratch on it, this assembly has a thin washer between the pulley and the oil pump drive spline is there suppose to be anything else in there? I know this sounds crazy, but is it possible for the oil pump to pressurize the cavity between the pump and seal to the point it would cause it to leak without blowing the seal out? I've seen a couple automatic transmissions blow the front pump shaft seal, just wondering
rustred
01-13-2019 08:23:26
if I was doing it and there was a new wear sleeve with the seal I would be replacing both. plus need to use a sealant on the wear sleeve. plus make sure the wear sleeve is installed correctly. and are these seals genuine ihc or other reputable seal and not Chinese junk. stupid question... but the seal is installed the right way and not backwards? need to ask questions as no pictures or visual on the subject.
ben brown
01-12-2019 19:15:34
the washer has a small cup to it or sorta cone shaped like a disk blade and is a splash guard and if it not there you get a leak also like been posted before i have seen them leak at key way also you could have a small crack in front cover
pete 23
01-12-2019 19:07:48
Are you installing the new seal flush with pump using a good flat plate so as to not distort the seal. You can, on some pumps, install seal slightly farther in but you need a plate that fits snug in counter bore or you will distort seal. Never use any tool that is chamfered on edge. Next, they have been known to leak past the key way in the crankshaft and that is what that springy washer (actually a seal) is on the crank shaft for so is that washer in good condition. Also, sometimes the key in the crankshaft will want to move with pulley and slightly distort the pulley. Hard to detect if only slight. I always heat the pulley in boiling hot water to make them go on easier but never heat in oven or with torch. Of course, excessive play in crank bearings.
Janicholson
01-13-2019 08:47:27
Re: 1086 front engine seal leak in reply to pete 23, 01-12-2019 19:07:48
Welcome Back, We missed you!!! Jim
Pete 23
01-13-2019 07:21:58
Just to add a little more information. Originally, these engines did not have that sealing washer when first introduced in the 66 series tractors. It is not the same as the larger oil slinger washer that was common on almost all older model engines. It is a very narrow washer and technically should be replaced with a new one every time pulley is removed. We had a lot of new engines leaking and that sealing washer was a improvement IH came up with.
rustred
01-12-2019 18:41:29
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
I NEED A PC160 FOR JOHN DEERE 100 DISC LET ME KNOW WHAT YOU HAVE
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
