Company Logo Shop Now
TractorLinks.com
C 20 Tail Wheel
lmack
01-11-2019 17:44:18
Where can I find the tail wheel (thin metal only) for a C 20 plow? My bearing is fine but I need the wheel. I have though about taking a small disk and cutting out the center and welding it to the old disk that has the outside edge rusted away.
OldFarmall450
01-12-2019 21:46:08
 Re: C 20 Tail Wheel in reply to lmack, 01-11-2019 17:44:18
WESnIL
01-12-2019 11:53:31
That should be IH part number PO 23 448. With the three sides and a curved edge that would be tough to make and look correct. Try Mike at Duffield Equipment (717)552-1951, Andrew Ginter (574)292-0248, Steve Smith (419)618-0017, or Andrew Tucker (812)878-7226 for possible replacement wheels.
Rex Simpkins
01-12-2019 01:39:31
You can look through newer IH plows and find a tail wheel that will work I used one off of a much newer IH plow the bolt pattern was the same only difference was the new one is not curved on the edge but flat, and its a lot thicker metal.
FastFarmall
01-11-2019 17:58:54
Yeah crafting one your self, or hiring some one to make one is a good option, at least your bearing and hub is good !!
