Company Logo Shop Now
TractorLinks.com
Super A help!
William1984
01-11-2019 14:15:13
Hello,
Currently in the process of restoring a 48 SA and hit a small stumbling block. Unable to turn the rear wheels. It did this while completely separated from the engine and front end. Shifter is in neutral, we reassembled the engine but can only turn crank by hand if clutch pedal is down. Can move shifter while pushing in clutch but the movement is erratic and doesn't line up with shifter grid. No movement at all from rear wheels. I've done a bit of homework and am wondering if it could be stuck in 2 gears or if the input shaft is jammed. In either case, or if its something else entirely, i'm not sure how to proceed. Would appreciate any advice anyone can offer.
Thanks in advance.
BarnyardEngineering
01-15-2019 04:52:08
 Re: Super A help! in reply to William1984, 01-11-2019 14:15:13
Yes, there are no drains on the final drives. The pans must be removed to get all the old oil out.
denglish
01-14-2019 07:53:33
Also, I would recommend taking the pans off the final drives. Then you can clean them out and inspect the bull gear. You'll need new gaskets, of course.
denglish
01-14-2019 07:52:18
As Old pointed out, the ice problem seems to be pretty common around here for YT members in cold climates. Surprising, how strong a block of ice can be. I had an M freeze up (literally) last winter and had to wait until warm weather before I drained a couple of gallons of water out of the differential.
William1984
01-13-2019 09:54:03
Take the top off of the transmission and look inside and look at the shifter rails. You'll find the problem. Post back if you still are
unsure.
Dave
Update: Rear end had a ton of water in it. Removed all the drain plugs (took me a while to find the final drive plugs) and put heat to the rear end and removed everything. Wheels spin freely now. Only issue i'm still having is the tractor won't find first gear. Goes easily into all the rest. Am going to try taking the transmission cover off and see what we can find.
William1984
01-12-2019 12:24:26
Thanks for the quick responses everyone. I will try your suggestions/things to look for tonight and i'll follow up. Is there a neutral position the shift rails should be in? (ie all lined up?) Thanks again.
Dave BN
01-12-2019 12:04:35
Take the top off of the transmission and look inside and look at the shifter rails. You'll find the problem. Post back if you still are unsure.
Dave
old
01-11-2019 15:05:05
Could be stuck in 2 gear or if it is where it is cold could have water in the transmission and or rear end that is now ice and that will lock one up also
504
01-11-2019 19:37:07
 Re: Super A help! in reply to old, 01-11-2019 15:05:05
Did you lock the brakes? They be rusted to the drum.
