Company Logo Shop Now
TractorLinks.com
f-20 wheels locked
khouse6
01-10-2019 19:20:59
bought an f-20. engine stuck. rear wheels will not turn. tractor has an add on road gear.
what could be keeping rear wheels from turning?
kenneth house
01-12-2019 17:10:08
 Re: f-20 wheels locked in reply to khouse6, 01-10-2019 19:20:59
i hooked a 140 farmall to the tractor, day or so ago, and it would not move on a down hill pull. hmmm
neighbor brought a larger tractor today, and the wheels rolled. thanks for inputs.
rustred
01-13-2019 10:15:32
 Re: f-20 wheels locked in reply to kenneth house, 01-12-2019 17:10:08
ooh boy, I guess a 140 would not move it. another lack of info post.
khouse6
01-13-2019 14:21:51
 Re: f-20 wheels locked in reply to rustred, 01-13-2019 10:15:32
hitched the 140 to it, on a gravel drive, and it pulled it. it was all that it wanted. (up grade) lol
Nebraska Kirk
01-12-2019 08:24:40
I guess you are not familiar with the F20 as it DOES have individual brakes and 9 times out of 10 if the rear wheels won't turn the brake shoes are rusted to the drum. The brake drum fits over the shoes and it is a major pain to get them loose and apart without breaking the brake shoes.
rustred
01-12-2019 08:32:39
 Re: f-20 wheels locked in reply to Nebraska Kirk, 01-12-2019 08:24:40
Ok, be like the W12 then. I know those get seized.
rustred
01-11-2019 19:26:29
im presuming your in a winter climate like here, so the bull gears frozen is the first thing to check , I have run into this a few times. with a tractor that old it makes the most sense. get a tiger torch and warm up the differential from underneath for an hr and it should be moving. cant see it being brakes because if its like the 10-20 its just a brake wheel outside of the case. there is no individual brakes to seize up .very unlikely those tractors get stuck in gear.
robgIN
01-11-2019 18:46:51
if the engine is stuck, the clutch may or may not be stuck, brake could be stuck, or as someone else also said could be stuck in 2 gears, and with the road gear, you shift the main transmission into neutral to engage the road gear, so try making sure trans in neutral, move the road gear lever both positions to see if it will roll. Frozen water in the trans or bull gear housings is also possible if in a cold climate. Or it just may be rusted and seized in multiple places. Take the drive coupling apart , if it still won't move you are going to have to start looking deeper.
sde
01-11-2019 08:24:03
Or a stuck clutch. If the engine is froze up and the clutch will not release the wheels are NOT going to turn.
used red mn
01-12-2019 10:38:37
 Re: f-20 wheels locked in reply to sde, 01-11-2019 08:24:03
What sde said doesn’t really apply, the transmission can still be in neutral and allow the wheels to turn. Unless something in the transmission is rusted up or seized. I agree with the brakes being the likely cause.
Loren in Iowa
01-11-2019 07:36:58
It could be stuck in two gears, at once.
formerly ny bill
01-10-2019 20:06:34
brakes locked up? I have one the same way. I removed the connection between the engine and transmission during the summer, and have the same problem. brakes locked are the only thing left.
rustred
01-10-2019 19:26:13
bull gears are frozen in water.
