F20 belt pulley shaft seal installation
SDE
I bought the seal a couple of years ago. Today is the day to put it in. Do you put it in dry or do you soak it in oil first? I doubt that I will use the PTO and so I thought about packing it with grease. It quit leaking. That's good, right? HAHA
TY
SDE
The belt pulley shaft.
When you turn on the Pto, the belt pulley is also turned on.
When you run out of oil, it stops leaking. It's empty.
I ended up tightening up the adjusting nut. It looked so close to the end of it's travel that I thought that it was as tight as it could go. Naturally,, I was wrong again. Hopefully it is tight enough now that it will not need to have the new seal installed.
TY
