Frankenford1
New User
I've got another question pertain to the priority valve selection. The one in particular that I'm looking at is the Brand Hydraulics Side-Ported Adjustable Flow Control Valve — 3/4in. NPT ports, 0–30 GPM, Model# PFC51-3/4. It does not have a relief valve and has pressure in and with pressure out on one and controlled pressure out on the other. With the return flow to my tank I currently have, is there a need for pressure relief or any other return lines. I found my pump specs. and they're 12 GPM & 1000 psi at 1200 rpm's. Idle speed listed of 500 - 600 is 6 GPM and 700 psi.
Appreciate any input to assure the proper priority valve selection. Thanks!!! Frankenford1
