Found the problem
bass
My 300 has been running ruff. Got some sunny weather do I pulled the valve cover and found #4 cylinder push rod into
I readjusted all the valves to .017h and now she purrrrrrs
Bass
53superC (plus some)
that's what i found when i took the cover off. i pulled that push rod to see if it was bent and ir was not so i put it back in place, readjusted all the valves to .017H
bass
I had that happen on a Deere A. The compression was OK, the mag had good spark, it was timed right, switching plugs side to side did not change the miss in that cylinder. Finally pulling the valve cover uncovered the problem. I about had my hair pulled out.
