Farmall 2 bottom mounted plow
ksguy
I came across this plow for sale so had to buy it, it looks like it would mount on axle housings of a h or m, I didn't get any part of the brackets that would lift it , has any one else been around one of these or have any information. Thanks in advance
https://www.yesterdaystractors.com/cvphotos/cvphoto8376.jpg
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto8377.jpg
We have a 2 bottom plow that uses a single point fast hitch to connect to our Farmall. The lifting for the fast hitch is part of the tractor. The A is mechanical and Super A up to the 140 are hydraulic.
(reply to post at 10:47:37 01/05/19) [/quo
i pulled a HM150 3 bottom disk with my H. yes parts bolt to the axle and there is a yoak that goes to the pin where the draw bar pivots on under the belly. there are bars that fit on the hydro pump housing that the cylinders push to lift the plow. takes a good half day to mount the thing.
Thanks I was wondering how they lifted it , wonder what the chances are of finding any
of the lifting parts I have the cylinders. I'm in eastern Kansas not many older mounted
plows .
