waukesha F 12
dieselford
New User
I am looking for a3in. piston for a Waukesha engine... 113cu.inch it is a Farmall F 12. the numbers are FL6D- 3x4 1933 s#FS2378. the piston number is- BD35A 3in. bore.
hopefully some one has one, I have it all but I one piston can some one help me. I have tried every place from the east coast to the west and no one has anything like it.i know that they are out there somewhere..
Thanks Doug
Do you know for sure you have std bore or larger?those engines were bore and sized from wear. I might very well have what you need. If it is oversize it will be marked on the top.
If memory serves, the model FC is practically the same engine but is 3-1/4 bore. You may be able to find a set of them easier and bore you block out to fit.
Doug, I rebuilt one two years ago and do have some left over parts! Have you tried Tom Underwood in KS? he is still selling off nos parts, can't say he has any though. My email is [email protected] John
thanks ...on the top of the piston it has the numbers stamped ..0005 and also 24 1/4 what ever that is? as far as I know it is std.
Thanks Doug
I am not sure if I have or not ..I have tried everybody all around this country..i sure appreciate the direction of tom. I will try to find his number.
What all do you have,in parts? still may need a few things
Thanks Doug
pistons, rods, ring, bearings, valves all used. If Tom has any would be NOS.
send me an email than I can send you pictures. I would have to check part # to match yours
Doug, Check my pistons they are BD35A std 3" if you have a parts book they do show .005 over bore piston so I am wondering if your are bored .005" over? Part# would be BD35AX5 on piston. What are your other 3 piston part # ? Have you checked bore for correct clearance?
