460 deluxe seat?
Dustyah
Cousin has a 59 460 farmall, with deluxe seat, complicated setup with dual rubber torsional biscuits, the aluminum arms on the rear broke, seat shows heavy wear, where can I get parts or whole seat setup, w/o breaking the bank, thanks lemme know , Dusty
Just take deluxe seat off and put a good regular seat on it. Any seat from a 300 through a 560 will fit base without drilling
I opted to repair the one on my 560, I put 2 seats together basically. It was a real pain to repair. Those aluminum arms are hard to find, I think my IH dealer said they would come from a long ways away, and they tend to break when you try to remove the groove pins that hold them on. I also got a bushing kit that I put on at the same time. I tried fixing the aluminum bars with JB weld with little success. One is still missing the outer end but seems to work ok. One of the aftermarket suppliers has the seat assembly, without cushions for around $150 I think but I can't remember if it was Steiner or Al States.
You can get those support arms from bates corp. IH tractor parts. I got two a couple of years ago to repair an extra seat I was able to pick up. Plus they are made out of steel! hope this helps, john
bthanks Mijohn, exactly what I was looking for, great tip, thanks a bunch you guys always come through. Dusty
