656 hydraulics
No. As was said,you will loose approx. one gallon. Place a bucket under the filter housing before removeing cover.
I was told by an old IH guy to run the rear tire on the filter side up on a block of wood or a ramp, tipping the tractor enough so the oil doesn't leak out. I still think it's a good idea to drain some out so you can see what it looks like, in case of water or contaminants in it.
