We have a problem that has us stumped. We restored a IH 350 utility which included installing a remanned TA, the old one was shot. Cannot get the new one to work. In taking off the inspection cover we noticed the clutch disc doesn?t get squeezed between the clutch carrier and the clutch cover assembly, pressure plate. The clutch release bearing does push against the release levers to disengage the disc, but when engaged the release bearing is way off the levers. If the clutch disc was installed backwards causing something to hit the discs hub, there would be pressure on the disc but it seems to be still very loose. The disc is .320 inches thick as recommended. We may have to split the tractor again to see what gives. Thanks for any thoughts on this problem, fun times.
Sid and Matt
Sid and Matt
