Cleaned up and adjusted clutch to specs. Greased throw out
Bearing and sanded up clutch pad. Everything looks great. No mouse nests or rust to begin with. Made a dummy shaft up to align clutch pad during reinstall and now I can?t get the end of the spline shaft to align with flywheel. Clutch housing is about a inch away from being able to bolt up. There?s nothing in the manual but , is it possible that the clutch and flywheel have marks on them that have to be aligned back up so they go back in same place?
