Company Logo Shop Now
Order Farmall Cub Parts Online
Froze Cub Engine
Farmallb
12-28-2018 10:11:10
Ive got a 1950 Cub Farmall engine that WASA froze up. I got it loose finally, but the valves were stuck. I got them loose also, manually, but when i turn the crankshaft, the valves dont move. What could be the problem? Could there be a timing chain that broke? AND IF SO, where can I find a new one?
mattofvinings
12-30-2018 17:02:08
 Re: Froze Cub Engine in reply to Farmallb, 12-28-2018 10:11:10
A good soak with some marvel mystery oil has helped me solve some flathead valve stick issues. You can generally reach the stems (at least the open ones!) from the spark plug holes.
A good sunny day with minimum wind can help you quite a bit.
john *.?-!.* cub owner
12-28-2018 19:18:47
Behind the carburetor os a long plate held with 2 bolts. Remove it and see if cam shaft is turning.
Farmallb
12-29-2018 10:56:43
 Re: Froze Cub Engine in reply to john *.?-!.* cub owner, 12-28-2018 19:18:47
I removed that tin plate. Had to to try to free up the valves. Im not going to do anything else with it till it either hits 50 again, or comes springtime. Gene, Ill keep you in mind for parts. Thanks.
1954Frank
12-28-2018 16:44:54
You may be aware there is a website and forum specifically for Farmall Cubs: farmallcub.com. They have an active and friendly forum and you should be able to get some helpful advice there.
gene bender
12-28-2018 16:36:17
I have a cub engine for parts if you need some
old
12-28-2018 10:30:24
If all the valves are close or not moving then you have big problems. Of course no matter what you should have a few valves open or you have a big cam problem. If when you turn the engine over no valves move then you have a broken timing gear or broken cam shaft or if it has a key way the key could be broken. If you do by chance have ALL the valves close then it has to either be missing the cam shaft or it is broken
Bob
12-28-2018 10:19:56
Are the valves stuck open, or a mix of open and closed?
If that's the case, you must have broken a cam gear or possibly the camshaft, as there's no timing chain.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Farmall three piece grille reforming tool set for A, B and C models, Repairs horizontal bars of grilles to original factory shape. Die also acts as a gauge for correct spacing between bars. Instructions and tips included. Buyer pays shipping. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
