RE: Clicking noise in International cub wheel
Satohbill
Just bought a 1967 International Cub that had been sitting for a while. I got it up and running but I notice a clicking in left rear wheel when running in second gear. I just recently added oil in the wheel and it was very low. Any ideas on what the clicking noise is. Is it possible it will quiet down once I drive the tractor more since it had been sitting?
The first thing I would check is to make sure the bolts fastening the rim to the wheel centers are all tight.
No the weights are secured with different bolts. The center attach at the rim. the weights attach to the centers.
Chuck
Does the noise change when you hit the brake? Brake drums are attached with set screws that sometimes get loose.
