Scottchbright
New User
I have a new to me, 70 2444. I have had it for a few months and it has now developed a hydraulic problem. Everything works fine for awhile then it slowly starts to loose hydraulic power. The steering gets hard and the bucket and gannon stop working. I?ve changed the filter on top of the trans, next to the steering and I have the suction filter from the diff area ordered. When checking fluid level in the diff plug behind under seat, I noticed it was empty and all the fluid was in the transmission. When I pulled the plug on top of the trans, hydraulic fluid gushed out. Why is it not returning back to the diff area? If it sits long enough, it will work again, then repeat. The tractor has the single hydraulic pump on the side of the engine, next to distributor.
