Super H Carb settings
Phil Tibbetts
A while back it seems somebody posted the initial settings for a Super H carb after rebuild to start with. I have checked and I can't seem to
find it. I have my carb apart and soaking and would like to have them if anyone has them. Next time I will print them out. TIA
Based on my experience (I own a a pair of Super H's), an initial setting for the idle mixture is one turn open and the main mixture 3 turns open should get the engine running. Once warmed up readjust both as required for smoothest slow idle and best (no black in the exhaust) high idle.
His is close , myself i stat off a one and a half turns open on the bleed and four and a half on the load . Depending on what your doing with it either for play or work on the main i will run from four turns off seat for play to five for work . , never wean fuel to and engine as LEAN IS MEAN .
