300 utility touch control
5 Forward
I am wanting to rebuild the touch control due to its continuous seepage. I have looked on the case-international parts list for a kit number, but only come up with each individual part number.. Does anyone know of a repair kit for the rebuild. Any suggestions would be appreciated.
Tom is correct. There May be New Old Stock (NOS) in someones collection, but there were never "kits" Unless the spools, or housings are worn, new Orings should seal it up. Some orings can be replaced with better quality Teflon, or synthetic modern materials, but shopping for the exact size replacement is tough. Jim
I did mine several years ago and the only way to get the parts is to order each O-ring separately. I would also recommend ordering the garter springs inside the valve that holds the spool valve centered when it is released. When I did my valves, both springs were broken in my valves. I also had to make a wooden special tool to install the spring. It was like a missile's nose cone and an internal nose cone to fit over the piston while the nose cone allowed the spring to expand over it and slide onto the piston.
