Adding a liquid tank to a 140 for side dressing
jmandrze
I would like to add a 25 or 30 gallon liquid tank to my 140 so I can side dress liquid when cultivating. Anyone done this before and could you share pictures? I was thinking to add it on the opposite side as the dry side dressers. Below is the what mine looks like.
Jason
I'm pretty sure I have a set of mounts and rings that fit about where your side dresser is. I have my uncle's old 140 that he used to put a tobacco transplanter on and that's where he mounted the water tank - about 40? gallons. When that tank went bad he mounted it on the transplanter itself. I can look this weekend to be sure that is what I have. Of course it hasn't been used since the '80s :-(
Water barrels for tobacco transplanting were mounted on the left side of the
tractor opposite the fertilizer side dresser.
My Dad had a small plastic tank mounted behind the seat and above the pto level. He used a pto spray pump and ran a hose from the control valve down behind one of the shovels on the cultivator. this is how he side dressed 28% while cultivating. Had to rinse the pump and fill with diesel fuel between uses. Al
I have mine set up so the 30 gal tank is mounted on top of the rear cultivator arms with black poly pipe running under the platform to front right
inside shovel. Works perfect and only takes minutes to install or remove. Sorry I don?t have a better picture, but I use my 100 for plowing snow
in the winter and strip all the cultivating parts off.
