Farmall C can you put wet lines on it
Ok you want to install a hydraulic remote.
There is a factory remote that replaces the original hydraulic lines on the side of the engine, but these can be hard to find sometimes.
Another option is a bypass block, which you can get at your local IH dealer or from eBay. This allows you to set up a generic hydraulic remote valve and your own hoses.
