560 ih motor my 282 diesel timing tractor wont run smooth at high speed breaks up unless you turn the pump to full advance no more adj left starts good but clacky when ideling book calls for the marks to be lined up 3 degrees before top dead center this don't seem to work could the auto advance be set up or not working i had the pump cleaned by a diesel guy he claims its ok I just over hauled the motor new sleeves rings pistons bearings wrist pin bushings total head reworked new valves guides and seats plus new gaskitts i have a ton of money in this motor i think its in the pump it run s like a scared cat top end and idles good no smoke till you open it up then its black the only thing i haven't done is tear the auto advance apart to see iff its set up any ideas help1!!!!!!!
