Re: Farmall C we’re to locate temp gauge
Rick Remmert
11-14-2018 11:29:49
Does your tractor not have a small gauge panel in front of the gear shift lever? Should have a fuse holder, light switch, ammeter, on-off switch and a temperature gauge.
Farmall1820
11-14-2018 15:16:21
 Re: Farmall C we’re to locate temp gauge in reply to Rick Remmert, 11-14-2018 11:29:49
I know we’re the gauge goes but was wondering about the other in .Do I take a bolt out or drill hole.
Chris NW Ind
11-14-2018 17:38:22
 Re: Farmall C we’re to locate temp gauge in reply to Farmall1820, 11-14-2018 15:16:21
Check the picture posted, shows where the temp bulb goes. Base of the block water outlet. It's possible the straight C isn't setup for this.
Chris B.
