Farmall 706 Wiring Diagram cont...
Navajo350
Not to be greedy because the wiring diagram a responder gave really helped compared to what originally came with the new wiring harness, but any ideas of where to look for hooking up the horn and air cleaner option?
Bob
for the horn it pulled power off the pegged post to the buttom to the relay and the relay pulled power from the starter post and from the relay out to the grill for the high note horn that sounded like a dyeing cow . the air filter restriction gauge pulled power off the key switch side then out to the sender and from sender to ground.
(quoted from post at 08:43:43 11/14/18) for the horn it pulled power off the pegged post to the buttom to the relay and the relay pulled power from the starter post and from the relay out to the grill for the high note horn that sounded like a dyeing cow . the air filter restriction gauge pulled power off the key switch side then out to the sender and from sender to ground.
Ok, thanks a lot.
Bob
