super a hydraulic pump
NAPA. take the old ones as a sample for them to match up.Find the old guy who has been there forever.
(quoted from post at 07:35:29 11/14/18) NAPA. take the old ones as a sample for them to match up.Find the old guy who has been there forever.
I order my o-rings for any application from a dealer who can give me exact size and material to seal the lubricant it is meant to seal . Not all o-rings compatible with all fluids . In other words I find the part number on Hoobers and then order from a local tractor dealer who carries IH parts .
I've resealed a couple of SC pumps.havent had a failure yet. Be sure to 'clean' the shaft/sealing surface with fine emery cloth before you put it together. The shaft will have a ring worn on it.Emery that area.
