RoeFarmall
Do I need to remove the end of the universal coupling before I remove the bearing retainer "housing"? If so, how do I get it off? The bolt and washer have been removed from the coupling and shaft. I am pretty sure one of the upper transmission bearings are bad and I am preparing to pull the top cover off. I want to make sure that I will not damage anything in the process of doing this work.Incidentally, do I need to mark the orientation of that end coupling?
As usual, my thanks, in advance!
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto2214.jpg"
