I’ve been working on my 450 (https://forums.yesterdaystractors.com/viewtopic.php?t=1366518). I’ve replaced the radiator, new wiring harness, a couple of new hydraulic lines, changed oil and filter, drained the hydraulic and replaced with hytran, and yesterday moved on to the transmission.
Drained about a gallon and a half of water out with the oil. I put 10 gallons of diesel into it and ran it around for about 20-25 minutes. Up hill, down hill, 1st thru 4th gear, & reverse. Drained it right away and it came out milky which was no surprise.
However, after I drained it, I found pieces of a bearing cage (no bearings) plus what I would guess to be a 1/4” thick layer of sludge still in the bottom of the casing. There were no grinding or whining noises when I drove it around. The oil condition and sludge on the bottom of the casing lead me think these pieces may have been there for a while and are not a recent failure - but I don’t know.
At this point, I’ll likely not pull the top cover and get into it this fall and winter (I work in an old barn and have no heat). I don’t want to leave it empty to draw moisture but I also don’t want to put 15 gallons of hytran in it just to drain it out in the spring.
Question 1: any concerns using an off brand (TSC) hydraulic oil as a “filler” until I can get back into this project? This does have the T/A.
Question 2: any suggestions for a good way to clean that sludge out without doing a tear down?
Thanks in advance.
Thanks in advance.
