Farmall 706 Wiring Diagram
Navajo350
Anybody have a good, clean wiring diagram to help a person out wiring the 706 gas? One with all the bells and whistles. Is there some place online? The diagram that came with the new wiring bundles isn't the best.
Bob
Well i have the factory one in one of my books , now what ya have to know is it a early 706 or a late 706 , is it a gasser or a diesel / Myself i build all the harnesses myself to the book color of wire size of wire and the correct terminals and plugs used , then i add some things and remove some things . I do away with the fuse and replacce with self resetting circuit breakers i also split up the light switch and add in C V relays , i use a lot heavier hot wire from the alt if equiped to the hot post on the starter . I prefer mine to what is out there forsale.
