350 battery box
Nick167
11-10-2018 12:06:00
On my 350 farmall the battery box under the seat is pretty rough and I need to replace it. Is there others that will fit like off a super h? I’ll try and find a good used one if I can thank you.
Nick167
11-11-2018 18:18:57
 Re: 350 battery box in reply to Nick167, 11-10-2018 12:06:00
Thanks guys! I’m gonna try and find one soon both front mounts on mine are rotted out
DR. EVIL
11-11-2018 03:40:55
Good luck finding a usable Super H battery box seat base. I replaced the one on my Super H about 1981. And my SH was a lightly used low hour tractor. I worked in the office at Farmall, had a buddy tell me when a bunch of seat base battery boxes went to an excess & obsolete broker. I bought two, $5 each. Should have bought the whole pallet of them!
The boxes are all similar, bottoms the same, rear "legs" the same, just the way they were assembled was different.
D Slater
11-10-2018 16:57:44
Only one exactly like a 350 was a 450 and maybe a W-450 but would need to double check on that one. 300 and 400 can be used. Main difference was light and rear socket mounted on different sides. Original supers didn't have the opening for battery cable at the bottom and rear mounting was different. Also no mount holes for hydraulic block. Aftermarket makes some fit all ones to use on supers through 450 and other types of boxes. some close to original and some not so close. Hard to find good used ones for sale. New is around $80 on up depending on how good or the seller.
