Company Logo Shop Now
TractorLinks.com
super c engine kit.forgot to ask
dewy
11-08-2018 16:59:09
pistons are stepped head and dont have arrow pointing towards front...does it matter which way they are facing.........thanks dewy
David G
11-08-2018 19:39:17
 Re: super c engine kit.forgot to ask in reply to dewy, 11-08-2018 16:59:09
As stated, the dome should fit up into the valve cavity.
gene bender
11-08-2018 18:57:45
check the head as they can only go one way
dewy
11-09-2018 16:39:31
 Re: super c engine kit.forgot to ask in reply to gene bender, 11-08-2018 18:57:45
thanks Gene....national treasure...........dewy
dewy
11-08-2018 17:51:50
i know which way the rods go..........thanks
Roger Tomfohrde
11-09-2018 05:26:14
 Re: super c engine kit.forgot to ask in reply to dewy, 11-08-2018 17:51:50
I was commenting that if the old pistons were still on the connecting rod it would show the direction of the piston if it had domes. Sorry my bad for confusing you.
Roger Tomfohrde
11-08-2018 17:49:49
Yes, there might not be clearance for them in the head. Did the engine have them in before. ,You could go by the numbers stamped on the connecting rod by the crank end usually go towards the cam shaft.
