Company Logo Shop Now
TractorLinks.com
IH 230 Windrower
pcrh
11-06-2018 19:56:05
Hi:
I have a model 230 IH windrower. The left outside roller bearing is gone. I got it apart and this looks like a bearing with a rubber covering on it. The rubber covering looks molded to the bearing. Is it? Should I be able to pry the rubber off to get at the bearing?
Thanks
pcrh
11-16-2018 20:02:54
 Re: IH 230 Windrower in reply to pcrh, 11-06-2018 19:56:05
Hi Harry:
The part numbers I have are as follows.
For the bearing 84330054 is a replacement part for the obsolete part(s) 608130R91
For the rubber retainer Part No: 592142R1
And for the support arm Product No: 824563C1
Thanks
harry r
11-16-2018 15:21:58
if you could find the part number i may have one or 2 if they are the same as on the IHC 201 swather. Have been going thru parts as i am retiring and going thru the misc parts i still have. Have not had the swather for a long time but remember some bearings in a round IHC tin and cardboard can.
pcrh
11-07-2018 18:21:17
Hi used red MN:
Exactly what I need. Thanks for the link.
pcrh
11-07-2018 07:20:58
Hi Millwright:
Thanks for the reply.
"Draper roll" as in the roller on the left side of the table to roll the canvas on. Yes that bearing is toast. The rubber sleeve seems ok. It looked to me to be molded and i did not want to force it off until I knew if it was part of the bearing or not. Now I just have to see if I can seperate the two.
Hopefully when I seperate the two the number will still be visable. Would you know the bearing number just in case the number cannot be read?
Thanks
used red mn
11-07-2018 10:09:11
 Re: IH 230 Windrower in reply to pcrh, 11-07-2018 07:20:58
Poke around a little in the IH online parts book at the link. If the diagram shown isnít the location of the parts you are looking for click ...Back to the manual... for more choices.
Millwright
11-07-2018 04:06:05
If you are describing the the draper roll bearings then yes the rubber is an isolation sleeve that is separate piece, they where still available at the dealer a few years back.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
