Farmall M Fuel Fitting
DelMN
I would like to know what size the threads for the fuel line nut by carb is. It appears to be a NPT and about 1/2 inches wide. This is the nut that goes around the fuel line. I am 150 miles from tractor so I can't just go and try to match it up to something. Thanks in advance for any info that you give me.
If having problems with swivel nut on end of fuel line (threads messed up), I would just find another fuel line from salvage yard. That nut is part of fuel line. If having problems with where it screws on to the carb, that is a separate fitting that will unscrew out of the carb.
It is not NPT. It does have a fine mesh screen attached for final fuel filtering. New fuel line fittings are available. Have you checked right here on YT?
