I was over at the old fellows house today with the Super M TA. He does in fact still have the original wide front. Just had the W9 front put on to use the loader on round bales. Makes it a little more interesting. I'll try to get pics tomorrow.
On another note, he also has a pretty nice 706 gas. It has set in a shed for a few years as well. Put some gas and a battery and it fired right up. Runs good. Problem is the a power steering line right underneath the radiator started leaking and the tractor won't turn to the left. Hyd oil squirting out from right underneath the radiator. It turns right, but nothing to the left. Does anyone know if the line, which I assume has a rusted hole in it, can be found? Through all the oil and grease it appears to go from the PS pump in front of the radiator along the frame and to the pump about midway on the clutch side of the tractor. What sort of job to get the radiator out and the line switched? Thanks again for the good information - Bob
