JAsher452x
So yesterday I was out tinkering a bit. Fired up to 606 and went to hook up the spreader to do some work on it. Brought in up to the shed, and decided I was going to adjust the clutch and TA on the 606. Ever since I have owned it I have never been able to get the adjustment perfect. I have been able to get it close and have just lived with it, as in I might have to pull the TA handle a little to get it to come out of gear or to keep it from grinding. I know the adjustments and have read many times that those are for new machines. older machines have wear and may need to be tweaked to get results. So before I started anything I inspected all the linkage pieces. every thing looked good, some wear in pins, holes not egged out. Standing on the side of the tractor I then applied the clutch with my hand to observe all parts then released. I then pulled the TA handle to observe all parts then released. The thing that stood out from my observations was when I would apply the engine clutch, the TA clutch release shaft would move towards the front of the machine. it was not rotating but a linear movement of a 20-30 thousandths. then it would rotate. Then when pulling the TA handle it would move in a linear movement to the rear of the machine about the same distance before rotating. So I think I have found what is causing my head ache. My question is are there bushings that go in the frame for the shaft? I have looked on CASEIH parts with no seeing any for the frame or the shaft. I would have to pull the shaft and measure to see of the wear is on the shaft or the housing. Also is this able to be removed by pulling the top cover off the clutch housing and sliding it out without a split? thanks in advance Josh
