Farmall 560 Tel-a-depth valve
bhshot
Recently the steel hydraulic lines running from the tel a depth valve to under the seat have started to leak. Due to the fact that I really don't use the fast hitch and the extremely high cost to replace the steel lines I have decided to delete them. My question is if I un bolt the lines from the top of the tel a depth valve can I plug the holes in the valve with standard type pipe plugs? Also what position should the input lever be in? up or down? Thanks
Is it possible to use hoses? Also lots of
teledepth valves replaced with regular
valves. Do away with lot of linkages.
Fast Hitch cats meow for hooking up to
things
