Looking for wider audience - posted the same on RP too...
Been wanting to post a video with sound and symptoms of my otherwise trusty 756 gasser faltering at high rpms. ?First thought was gas flow. ?Screen from the tank to the carb is clear.
Background - after carb rebuild and thorough tune-up, the tractor ran like a champ. ?Mowed one field with my Krone disc mower conditioner - no problems. ?Couple weeks later, started mowing another field and about half way through the tractor started sputtering and trying to stall. ?Drop back to idle, and the engine recovers. ?Put it under load - after a bit, it repeats.
I've been using the tractor for light duty chores and good. ?Recently, the problem has become worse. ?Probably time to do something...
Any ideas?
Thanks!
756 Rough Running...
Any ideas?
Thanks!
