Farmall bn carb
Chris450
New User
I just got a new bn. I got it running but will only run with the choke pulled out. So I want to go through the carb. The problem is the tag is missing off of the carb. I know it's a zenith but I don't know the model to order the correct carb kit. Is there anything I can measure or check to find out what I have?
When I have that problem I take the carb to the auto parts store. My Local O'Reilly's keeps a good number of tractor carb kits in hand so then you can compare gaskets etc. to get a kit that will work
You also might try this. Pull the main jet cap off and make sure you have a good flow of gas out of the main jet. Lack of flow will cause the problem your having. I do that and poke a piece of wire into the main jet to clean it out
