1967 International Cub Headlight wiring diagram
Satohbill
I still have the original light switch on my cub. It has 3 terminal connections on the back maybe 4. I found the hot terminal but not sure what goes to the other terminals. Does anyone have a diagram.
I don?t know myself, how many positions does the switch
have? How many lights does it have? If only off and on
maybe each light?s power wire attaches to its own terminal.
On a 1967 cub there should be a resistor on the back side and the head light wire should go to the one side of the resistor for the high and low beam then you should have two posts for the rear tail light , one side is for the rear RED ROD light and the other is for the WHITE work light , Now tih out putting my BOOTS on and walking out to the truck and bring the BOOK in the way i would work this is your HOT wire should come off the fuse and it should be fed ya a wire coming off the L terminal on the reg. to the fuse or it could come off the amp gauge to the fuse then to the light switch . Ususall the hot post of the light switch sets at the top when the switch is installed correctly and it is pretty much idiot proof due to the small tab that fits in the slot in the dash . First click on should be low beam and red light second click should be high beam and red tail light and third click shoulld be high beam and white light on the back. Now as to the color of w2ires on this i would have to put my boots on. Nah that ain't happenen today.
