Ellis Kinney
To justify many questions, I will say that I have 3 M Farmalls, consequently 3 times as many questions. My distributor is filling with oil. To prevent this
after about 4 or 5 hours of operation I drain the little plate under the distributor. This is a standard M with the belly pump. I probably need bearings or
seals. Is this a difficult job? I have read over and over about putting the distributor in backwards, how do you prevent this? How do I know if I need a new
distributor? Any other suggestions would be appreciated also. Thanks, Ellis
