Farmall & IHC Tractors Discussion Forum |
another question
Author |
[Modern View] |
Ellis Kinney
10-25-2018 08:43:35
To justify many questions, I will say that I have 3 M Farmalls, consequently 3 times as many questions. My distributor is filling with oil. To prevent this after about 4 or 5 hours of operation I drain the little plate under the distributor. This is a standard M with the belly pump. I probably need bearings or seals. Is this a difficult job? I have read over and over about putting the distributor in backwards, how do you prevent this? How do I know if I need a new distributor? Any other suggestions would be appreciated also. Thanks, Ellis
D Slater
10-25-2018 17:57:47
Re: another question in reply to Ellis Kinney, 10-25-2018 08:43:35
Ignition drive housing on a M didn't have a seal until the first month of 48. Something is wrong getting that much oil seal or no seal. Crankcase vents clear, oil drain back from housing blocked by sludge or bushing worn out? IH distributor has a seal ring on the shaft. If bushing is okay the distributor needs the drive gear pin removed from the shaft and breaker plate removed after cap, dust plate, points and the terminal stud removed to pull distributor shaft up or out to replace the seal ring. Sounds like you have a later distributor gear housing than a M, maybe it was magneto equipped and has the housing without the seal. If you can find a cast number on the ignition drive housing the one ending in just a D has no seal if I remember correct.
Ellis Kinney
10-25-2018 20:21:46
Re: another question in reply to D Slater, 10-25-2018 17:57:47
Maybe you are on to something, The engine I have in the tractor is not original. I think the engine is a 1949 and the tractor is a 1947. I had the engine tanked and rebuilt at an IH dealer a few years ago and I am sure they used the parts off the busted engine. Maybe something isn't really compatible. Thanks, Ellis
glennster
10-25-2018 14:57:07
there is an oil seal in the distributor/mag drive housing. i am looking at a w-6 manual right now and the part number for the seal is 352080 r 91. should be the same seal as the m.
Charlie M
10-25-2018 09:05:24
I can help you with the comment - putting the distributor on backwards. What can happen is you put it back off 180 degrees from the engine. If you have the #1 cylinder on top dead center from the compression stroke the rotor should be on or real close to the #1 spark plug wire in the distributor cap. From there you can do timing and get it perfect. Concerning seal, etc that's where a parts catalog comes in handy for me as I can look at the diagrams and see what parts are in there. You might be able to look up a parts diagram on the Case website and see what you need. Not sure what is in there without looking.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959.
... [Read Article]
Latest Ad:
Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
