M farmall 3point hitch cylinder mount
I just got thur putting a 3 point hitch on my m farmall.
It doesn't have a place to mount a hydraulic cylinder.
How does everyone else do it?
I thought about putting a cylinder from the pin where the lift arms attached to the tractor and building a bracket and connect it to the arm that holds the adjuster/ leaving mechanism?
Any pictures or thoughts will be greatly appreciated thanks
Post a pic of the 3 point.If you have the 3 point I think you have,you are going to have to weld an arm and lower anchor to the hitch.
It sounds like a welding project. Post a picture of your hitch and someone can tell you what to do. How did you get an add on 3 point hitch with out a cylinder hookup? You will probably want to remove the hitch again to grind and weld the brackets on. That is what I would do. Ellis
