warren woodrow
424 without front mounted pump or draft control - 5 gallons
424 with front mounted pump and draft control -17 gallons
Any idea why the huge difference ? This does not include lift housing as it is separate and holds 3 gallons. Just cannot understand why so much more
for draft control because all the mechanisms involved in draft control are located in the lift housing and use separate reservoir within the lift
housing . Of course mine requires 17 gallons of the hydraulic oil in the tranny and 3 more in lift housing.
