So, in doing a final cleaning of the fuel lines before installing the new lift pump on my British 444, I noticed that the fuel line is cracking from the flare at the tank fitting for about two inches. The part isn't easily replaced with an off the shelf part. Since the tractor is gravity fed from the tank to the water separator, is there any issue with me using rubber or plastic fuel line as long as it is diesel compatible?
I would also like to cut in an inline fuel filter as an added layer of protection until I get the time to do a proper job of the fuel tank.
Thoughts? Pics of conversions? My only concern is the banjo fitting at the water separator.
Scotty
Scotty
