Exhaust elbow
Gene Sage
Installing a DT 467 engine from a 5288 in a 666. Will the exhaust elbow from a 1066 or 1466 fit on the base and provide a vertical exhaust?
cording to the parts book the elbow should bolt on.Does the exhaust manifold flow to the middle or the rear?
It flows to the middle. The intake side of the turbo is to the rear and and makes a sharp bend to the airfilter. Compressed air from the turbo makes a bend to the front flowing to the intake manifold. How much horsepower will the transmission stand along with the final drive?
Seen quite a few that has done this.Need a double or triple disk clutch, needled rear differential , heavy input shaft, adapter rear for 400 engine,Ta eliminator or reworked TA. Leaman is a name of a guy that has these parts 1 717 464 2874.Have a IH friend that has a large IH collection he has a 560 with the 400 engine in it.
Working with Ed Leaman parts. He is supplying triple disk clutch, TA eliminator shaft, front and rear adapter plates. Not sure about the need for needle bearings in differential. Won't be a serious sanctioned puller, just a few county fairs etc and tractor rides. Probably start with a 11 or 13 mm head in pump and appropriate injectors and Snow water injection. At what point do I need to carry an empty HyGard pail to pick up parts?
